2011 HD Swap Info and Pics
Status
Not open for further replies.
Mike
Banned from GMFS
Mar 20, 2011
420
2
Indiana
Alright so starting this to give part numbers and for people to show pictures of their conversions.
-2011 HD hood- 20952912
-2011 HD bumper w/fog light holes (they call it "bar")- 25883349
-2011 HD grille- 20966058
-Fog Lamps- (Left side) 25883245 and (Right side) 25883246
-2011 Hood trim molding (Grille piece)- 20963700
-2011 Hood Vents- (Left side) 22753694 (Right side) 22753693
-Vortec Emblems for Hood Vents- 25909695
Now post up some pics!
HOW TO MOUNT 2011 HD FRONT BUMPER
Ok, so ill try to explain what I did the best I can. Im posting a picture at the bottom for reference because I didnt take pictures.
-I used the factory 1500 brackets. I cut the back of the bracket from the center to the outside of the truck. (The side that bolts to the bumper, from the center towards the tire if that makes sense.)
-Then part number 7 in the diagram (inner bracket), I unbolted and raised it 1''. I used part number 6 (anchor plate) as the templet and drilled TWO new holes, I didnt use the top hole. After I used part number 6 as a templet I cut a top portion off so it would fit back into place. (when you raise it up an inch, part number 6 is too tall to fit back into place so you have to cut some of the top off, I cut the top hole off when I did this)
-I put the mounting brackets on the truck and just put the bolts finger tight. Then with part numbers 6 and 7 relocated and cut I put them back on the bumper and put the bumper on the truck. You may have to wallow out some of the holes to get a perfect fit.
-After I got the bumper where I wanted it and I tightened everything down I pushed the end of the bumper where I wanted them and drilled a hole for the support brackets on each end of the bumper. (the bar that goes around the backside of the fog light) I only drilled one new hole for them and it holds perfect. It should have two but I didnt feel I needed both and it works fine for me.
*info from bryanatc
6827323119
I know its not a full HD conversion, but it deserves to be here too. Brandon's truck is just so sick
Status
