2wd 72 bronco build
Working on mocking stuff up. Trying to get it to roller status. I really should buy metal but found out I need drop spindles and can't use the spindles I have that cost zero
i didnt mean that, but i meant some random dude could come on here, see that and things its fine.
I would hope someone takes that bad advise. If you think things like that are right you should not be taking on projects like that. You should see the stuff people do that don't make it on the Internet
Worked on getting the brackets tacked onto the axle and get final layout. I need to order some new heims for the Panhard bar before I can mock that up. But trailing arms are mocked up.
It is so hard getting motivation for this project. I am at the point where I can spend 8 hours working on it and it feel like no progress was made. I was really hoping that taking the summer off would make it so that this didn't happen.
It's tough, I give you and all the guys that do big projects like this a ton of credit. Maybe take a break for a little bit and come back to it. Write out some small goals to do so it doesn't seem like you're not getting anywhere.
I turn wrenches for a couple of hours and I'm over it, big builds are insane and I guess part of the reason I find them interesting.
I think I just need to buy some parts for it. Usually when new stuff comes in I get the urge to work on it again.
I am really not that far away to be able to finish weld the frame which would make it feel further ahead.
Don't have time for a project of this scale. Changed priorities and would rather put the time in the nova
This is where I'm at with my C10. I won't be happy with the truck until I can really do a full build on it. Won't be able to do that for years and years so up for sale it goes.
