Antenna delete mod NBS
HackMcMaster
Jun 26, 2012
4,758
9
Dunes
this is pretty simple but i wrote it up with lots of pictures just so everyone realizes how easy it is
1: unscrew the antenna
which will leave u with this
2: remove this piece
to leave u with this
3: undo the three screws to unmount the base using a 7mm socket
Optional: for "improved radio reception"
create a wire a couple inches long with #10 ring terminals on either end like this one
attach one end to the base of the antenna (i used 10-32 bolt and nut, with washers)
sneak the base so it sideways down the fender
attach the other end of the cable to original mounts
end optional--------------
i put a dab of locktite on the threads
screw the antenna back on
lay the antenna down the fender and attach with zip ties
reinstall plastic piece
as you can see you still have a hole there if you want you can replace that piece with one off an esky which doesnt have that hole
PN# 15287179
Reactions: barrrf
I need to do this, but I need an antenna someone broke mine trying to steal it
someone tried to steal your antenna?
Yeah I had tighten it real good and added a little of jb weld, and they tried and. Broke it it was a billet antenna and I don't have the original one, they also tried to steal my tails, and corners, and denali's the same night. All they got was my third brake light. It was at my girlfriends old apartments
Seriously takes 5 minutes if u don't do the wire,
Btw my reception just randomly shot a brick idk
Also dont forget everyone - the trim piece that surrounds the antenna can be swapped with the escalade piece that has no hole for the antenna, looks a bit cleaner.
Nice write up.
Nice write up.
That info is at the end of the write up, with part number
For those that don't want to buy the escalade piece with no hole you can get a rubber plug to fill the hole.
