Check Engine Light ?
hddoc
Oct 18, 2013
62
Tampa Bay
Should the check engine light come on with just the ignition turned on ? Mine does not but all the other warnings do. I know it works as I have had it come on before I cleaned the MAF sensor. Thanks Doc
On a side note I had a 2004 Chevy SSR that when the ignition was turned on the gauges would sweep, this truck does not 2004 Sierra 4.8 reg cab. Should the gauges sweep ? Thanks Doc
Honestly it is very easy to do if you take your time and marketing where the needles were. After doing it a few times, it takes me less than 10 minutes to have it out and disassembled.
[/URL][/IMG]
Should I do just the speedo or all 5 motors ? Thanks Doc
I ordered the stepper motors and will attempt to do it myself. I have red lights now and like them and they all work. Thanks Doc
Installed new stepper motors and left the stock bulbs in place as they all work and I do very little night driving, Scotty's tread on the stepper motor install was a life saver for me. Thanks Scotty
