You can take 5 seconds off with better tires apparently so you should be in the 8 second range good job bro
Sent from limp mode cat eye.
Best i got last summer at 1/4 track while still working on the setup was 12.75@119, 2.4 60ft. Was just wanting to get it down the track, wrong everything pretty much but it moved down the track at a slow pace on 4psi. Things wrong at the time, small 3200 stall, nitrous cam, 3.42 gears and a 60e not equipped with any trans brake lol.
Stock bottom end 5.3, cnc'd lingenfelter heads, custom grind cam, 76mm precision turbo, dual wahlbro 355's off a DBRods cell, ID850 injectors
Don't have my slip but I went 12.33 at 113 last year
You should add yours too..... :cheeky:
