DA04 progress
Silver04
DA04
Aug 7, 2012
1,385
224
Firebaugh Ca
Well its about time I made one of these. Pic heavy. So here we go...
I got the truck in 05 bone stock. It was a grad gift from my parents.
Rollin on 26" idk y I thought that was kool???
22"s
Before I dropped it 2/4 was @ 2" in the rear in this pic.
2/4 belltech
chrome headlights
shaved gate
center console swap with some painted plastics
xentec 6k hids with stock amber bulbs
high 8 I also did high 10 but I don't think I have a pic
switchbacks from vleds 6k
6k drl
ss grille shell. friend of mine put 06 front on his so I got it for $30. cheaper than painting mine
blue leds for the interior
suede inserts thanks to my girl. I didn't have the patience to cut and glue it also remove all the wrinkles.
spikes from studesandspikes.com I have them on the rear plate as well
roliing
scraping frame. I used a wire wheel and a scraper. 1-2 coats of eastwoods rust encapsulater then 2-3 coats of rustolium oil based gloss black.
also painted calipers with some real red vrt. btw the red on the disc was removed.
reppin that cgm sticker. Also a antenna from jared.
Went out of town for some shots. This is the one I like the best.
took bed off to install flip and notch I also painted the top of the frame
sitting at 2/6 for now will be going to 3" up front
What a transformational! From trashy to classy man. Looks great
Soooooo clean dude, always loved your truck. :megusta:
So that's all it takes? When the drl is on does it flash with the turn signal also?
Gracias. N no the drl dont flash. To do that you need to do thr turn signal mod.
Vmax will stay red to flow with calipers unless I just peel the red off and leave it chrome.
got my calspeed lts in as well..:D
Put my rims back on. 265/35/22 nittos 420s.
Do like... hard to believe that I have the same size tire but so mash moar low....
