blome_racing blo me Mar 8, 2013 #41 run the good cvx in a bigger box... guarantee you it will pound harder than it did with 2
D Doug New member Mar 9, 2013 #43 Just match up your sub to your box. With the right box and the right subs it'll sound best.
Jared Administrator Mar 9, 2013 #45 by specs. Find out what your box is in terms of cubic feet, and get a sub that requires right around that amount
static06 New member Mar 13, 2013 #46 ProBox Custom UTV tops and Vehicle-Specific Subwoofers and Enclosures Has the specs on there. Says .80 cu.ft. per side 10W3v3-4 - Car Audio - Subwoofer Drivers - W3v3 - JL Audio "optimized to operate in a compact 0.625 cu. ft. (17.7 l) sealed enclosure" So, would the woofers work with my box? Edit: SA-10 requires .5 cu.ft^3. Dafuq does the 3 mean?
static06 New member Mar 13, 2013 #48 These are right around what my box is rated at Rockford Fosgate P1S4-10 (P1S410) 10" 4 ohm Punch Stage 1 Sub
BOO5TED Resident Smartass Mar 15, 2013 #49 linden said: when i get home ill get you the dimensions Click to expand... never made it home yet?
