NBS tahoe bagged, bodied, billets
I’ve said it before and I’ll say it again, if I ever win the lottery I’m just dropping off a truck and a bag of cash at your place to build me a truck. Awesome work
Reactions: Connor and Tukn4s
20200128_173720-jpg.869174
20200128_173731-jpg.869175
20200128_173755-jpg.869176
LST will be the last show as a roller.
Seats are in place. Will have floor ducting still. Rear seats also will function like stock.
Sent from my SM-G965U using Tapatalk
Trying to decide if I wanna roadtrip out to LST. Got some buddies going, just don’t know if I can get off work yet
Oof she bad can’t wait to put some miles on this thing
Spent some time working on the tahoe over the last week. Got all the body floor structure finished so I've pulled the body and began disassembly to frame to begin final welding and getting it ready for powder coating. I will be adding shock mounts and air tank mounts that also tie in the rear frame rails more.
Reactions: eand28, BB and Huck
Yesterday had a lot of grinding and clean up involved. Had to modify the passenger side upper arm mount closest to the radiator to clear for an a/c line with the lowered engine. Will hopefully have the plates for all the rear notch joints by this weekend so i can add the cross bars for the shock mounts and the air tank mounts.
This be my least favorite thing to do on these builds but it still must be done
Reactions: BB and Huck
I wish I had the space and fab tools to do that kind of stuff. Awesome work
I feel like I'm making good time when doing this stuff until i look at the clock and see how long it took to fit 1 piece
You ever consider doing IRS Brett?
Would think you could do alot less to the cargo area / bed by keeping the center section low and your pinion angle woukd be fixed
I would consider it if a vehicle wasnt going to have such wide wheels.
Spent some time finishing up all the crossmember fitting and doing the last test fit before it's time for frame prep and powder
Good work per usual Brett. Throwing around the idea of static dropping my tahoe and its amazing how little room there is for large tires and modified suspension/gears in the rear, its cramped for a fullsize. Full frame was the way to go, and mods to the door/frame are killer. Bet youll be glad to rip into something with a bed again lol
Speaking of...you still make those heim TRE's? Wish i woulda kept them when I sold my bagged truck.
Yeah, the tahoe/suburban and even the avalanches all are really cramped with how the gas tank/4 link/ and frame rails are. It's a challenge when doing these. Surprisingly the doors and rear weren't as bad as I anticipated.
I can make you a set of you need them
All the fab work is officially done on the tahoe chassis. Swapped the shorty headers for full longtubes. Turns out even with the lowered engine, the 99-06 speed engineering longtubes will work and do not hang below the bottom of the frame. The exhaust will be cut a little shorter to add turn downs on the ends and no go past the end of the frame.
Long time coming. Laid down the raptor liner today
Reactions: BB
