need some seriousss radio wiring help/declusterification!!
Bassmaster
Media Mod
Mar 8, 2012
10,302
147
South Jersey
truck: 2005 silverado ss with Bose system
previous unit: ~2003 Alpine IVA - D900 (DVD, Nav)
http://www.crutchfield.com/S-8N3LXNFkyyy/p_500IVAD900/Alpine-IVA-D900.html#overview-tab
new unit: ~2009 Pioneer AVIC - F700BT (Nav)
Pioneer AVIC-F700BT Navigation receiver at Crutchfield.com
i'll try and keep this short. i'm a radio noob; only installed a basic single din in my 1st car and Sierra, which was just one simple harness and radio antenna. i've never dealt with Bose system, and never dealt with any double din/nav unit before, so this mind fucks me.
this is how i bought the truck - with the Alpine unit out and in its box, with no unit actually in the truck..just all those wires. owner had the unit since new in about 2003 and said it still works..buttt then why did he take it out? idfk. he had a receipt from Circuit City when they installed the Alpine unit, which is why some of the wires are labeled i guess
my GOAL: install Pioneer double din, keep Bose system, keep steering wheel controls
my PROBLEM: have NO idea WTF all these wires are. which (if any) i will be able to re-use for Pioneer unit, and which new harnesses i'll need
black gloves are on because my white hand + flash = huge glare
Pioneer unit
Came with the dash kit and wires from a Ford I think? Will ask PO
everything is color coordinated for the most part, buy the two harnesses if you need them, install, crank up ur blose till it blows
i have no idea what is stock bose, and what is from the Alpine unit. everything is tied in together
updated OP with some pics
The harness that plugs into the gmos the factory Bose. Basically, anything that's wrapped in tape/foam is gonna be stock. You will have 2 factory harnesses
The GMOS-04 box that you've got is for your OnStar and Bose integration. That's good, that'll save you ~$100 from needing it. That harness should have the provisions for your parking brake, vss, and reverse wiring if your new Pioneer has Nav. Try to find the paperwork for the GMOS-04 so you can find the wiring diagram and subsequently start to sort out which wires are which. Like others said though, most of it should be color-coordinated. If you have steering wheel controls, you'll need to get a separate module for that. See here for that adapter.
Bohall since it was 'professionally' installed, everything is taped and neat looking. I can't tell what is factory bose (nor would I know anyway) and what is leftover aftermarket wires.
Everything is connected with each other through plugs on wire taps, which makes it a PITA
The gmos 04 has 4 plugs, one on each end, then 2 more off the wires next to it.
Big gray one runs into factory foam, small black one runs into single green wire w/ white stripe
Edit. I do have wheel controls and I know I need a harness for that, if he doesn't have it already.. I have no idea. My main problem isn't installing it right now, it is separating the stock from after market wires so I can return to stock and start fresh. See what I have/what I'll need. But with how everything is tied to in together, Idk what's what
sent from your HTC Rezound
Well basically, the harness with the
Purple pair
Green pair
White pair
Grey pair
Is ALWAYS after market. That's the standard speaker wire colors. So if the harness has all that, it's after market. And I would also be willing to bet whoever installed didn't wrap in foam tape, so if theirs foam tape, it's oem. However just from how it looks on my phone I think they used the fancy prewired plug and play harness, if that's the case get to choppin. My method for dealing with this kinda stuff, is to just unplug and remove everything. If it comes out its after market lol
i got on the phone with another forum guy for about a half hour which helped sort out a lot of the BS. here's a current review/recap vid
then some pictures for still references
i just have to disconnect the dvd bypass harness, cut & tape off the green dvd wire, remove extra power wire, and it is back to stock. dont know what ill do about that module under the back seat..
gmos-04 is a metra unit, definitely not stock but you probably know that, and like bohall said, ANYTHING with foam around it is OEM. ive never seen anyone rewrap aftermarket wiring with OEM foam.
do solder and use heatshrink on your connections, plz. takes longer but much cleaner
yeah shouldnt have said back to stock..rather back to just what i need. next ill take off that dvd bypass harness. as for the extra red power wire coming from the Alpine plug (non sticker side of GMOS - the big gray plug that plugs into big factory green one)..which end should i remove it out of? the alpine end, or gray plug end, or remove it from both because it doesnt matter?
and i wasnt kidding when i said i was a noob at this shit. i had really had no idea what i was looking at before lol learned a lot today about it all
Just cut off the red wire on both ends and tape it up really good. The red wire is no longer needed, snip off that green wire but keep it because you may need it for your new double DIN unit.The green wire should be tied into your parking brake.
correct. thats the dvd wire tapped into parking brake. i was gonna snip it then just tape it off. my new unit isnt DVD, but who knows if i'll get one down the road
did some clipping tonight and overly taped everything :lol:
cut the dvd wire near the plug
cut extra power wire
dvd harness OUT!
so, the black, red, and yellow wires i'm holding were cut from the DVD harness
they run up to this
which runs to this. you can see where they go. 1 of each into big gray plug, 1 black & 1 yellow come from the other set which runs back.
i also taped those two orange ones together (but not touching) because they were cut but left open
and ended at this. dead end green wire, GMOS installed right, black/red/yellow extra end, and thick power cord.
im thinking i can ditch where the extra end of black/red/yellow. cut the ends at the tri-way meet point..and splice just to the same gray plug wire, but wanted to double check before i went cut-happy loll
Wow, I'm surprised you didn't say I was a fucking dumbass for not being some electrical expert loll
But I was so frustrated with it yesterday that I was gonna say fuck it and get a shop to do it, but I got helped through the big bullshit and now it doesn't seem so bad
I would have just unplugged every harness connection, taken everything down to the factory harnesses and started over. Less confusing. Glad you're getting it sorted out.
