For Sale: NNBS 07-13 LineX Extra Fabricated Bed Tire Mount CUSTOM
AllBlkdOut07
Aug 7, 2013
58
34
56
This one off tire holder sits in the bed of your NNBS Half Ton 07-13 Silverado/Sierra and slides into and bolts up to the 2 bed rail holes closest to the cab.
Steel boxes slide into existing frame rails and use existing bolt holes in the frame rail on 1500 half ton Silverado years 07-13.
Made of variously sized seamless DOM tubing this is a unique piece that is very strong with a continuous tig weld beading around every notch.
Thick 1/4 plate holes your spare wheel/tire in place with 2 OEM GM wheel studs so you can use your own lug nuts an even a lock nut.
Designed with three support legs that can be bolted down to your bed for extra strength, but you could get away with not doing this if you don't want small holes in your bed.
$550 Local pick up [no shipping]
