For Sale: NNBS 07-13 LineX Extra Fabricated Pre Runner Style Light Bar CUSTOM
AllBlkdOut07
Aug 7, 2013
58
34
56
This one off lightbar has been coated in LineX Extra and bolts right up to custom steel plate boxes fabricated for this lightbar.
Steel boxes slide into existing frame rails and use existing bolt holes in the frame rail on 1500 half ton Silverado years 07-13.
Made of variously sized seamless DOM tubing this is a unique piece that is very strong with a continuous tig welding bead around every notch.
You'll need to remove the lower fascia to install the boxes. The boxes replace the tow hooks so you won't be able to run both.
Wiring is inside the DOM tubing so it is partially hidden. Weather pack connectors make for a watertight seal.
Lights are not included but are available, I'm selling them separate.
$400 Local pick up or [+ shipping] but I'm sure shipping would be $$$.
