Obs lift suggestions
Chris.G.Jr.
Apr 29, 2012
714
31
Bartlesville, Oklahoma
Alright guys I have always wanted a lift but never knew what kind to get and im thinkin about the cepek 6.5 lift and a 3 inch BL. The only thing is is i have no idea what all id need to upgrade as far as gears, rear end, differential, driveshaft, etc. on the cepek lift i know theres a series 1 and a series 2 and i know the difference is series 2 has the fully adjustable x member with heim ends to lock in the front and rear crossmembers.
i found a couple different sites to get the cepek but i have some other questions
what gears should i run?
do i need to get a new rearend? if so what should i get?
do i need a longer or more durable differential?
longer driveshaft?
one site lists a autotrac driveshaft would i need that?
do i need the front double shock kit?
same site lists rear lift option with options being 5" block, 4" block add a leaf, or 5" block add a leaf?
do i need a steering stabilizer?
What type of bodylift do yall recommend?
anyone recommend a different lift kit?
i think im gonna end it with a dumb question...
is there a kit that includes exactly everything i need? (driveshaft, differential etc)
heres a site i found
Dick Cepek Chevy GMC Suspension Lift Kits
well shit one site is out of stock this site, i tried the buy now and it didnt add it said cannot add this to cart so shit
guess im looking for somewhere to get a lift or what lift and extras to get
maybe skyjacker or rcx or rough country? or?
lots of people buy the RCX kit. Good kit. the 4 and 6 are same kit. Just with an AAL. so buy the 6. Your angles wont be amazing with the 6" although because same parts as the 4".
dont know, but I always heard RCD was great on FSC when I was looking for lifts with my OBS. DCII never had complaints, and a few had BDS. RCX has great reviews too, most dont have complaints.
I think for the money I would run RCD or DCII (are they still making them?)
is there anything to do to get the angles back?
any thoughts on skyjacker lifts?
correct me if im wrong but leaf springs give a better ride then just the regular lifting blocks right?
idk if they r making the dcII lifts bc the two sites i was at one said out of stock the other wouldnt even add it to the cart and i read a few results from google search that they aren't making them anymore
See my responses below Chris.
Depends on your tire size choice. For 33s, personally, I would run 3.73s or 4.10s, for 35s, 4.56s or 4.88s.
If you have an open rear end, it would be beneficial. Alot of people use Detroit TruTracs with success. Check out Ron's Machining Service for parts here.
You will not need to make any changes to your stock differential.
longer driveshaft?
Your stock driveshaft will be fine, the only trucks that need to swap are Tahoes/Suburbans with Autotrac transfer cases.
See above.
You don't NEED it, but some like to add it, mostly for looks.
There are quite a few ways to go about lifting the rear. Some like blocks, some like blocks and add-a-leafs, some like shackle flips. It's all preference. Add-a-leafs do tend to make the ride a little stiffer though, if you do get them you may want to upgrade to a better shock than what the kit offers.
Not a necessity but helps especially with larger tires, they're pretty cheap too.
I'd go with Performance Accessories although I would not get a 3" out of personal preference. I'd snag a 2". Make sure the kit you get comes with both sets of bumper relocation brackets, some kits only come with the front. Bumpers look terrible when not relocated properly.
Since you want a 6+3, maybe look into a 9.5" FTS or 10" Cognito kit, though the Cognito kit may be hard to find.
wow! thanks alot that really helps man! when a lift comes with the add a leafs is it necessary to actually use them or are they a "extra" item to use for your own preference?
and if i did get the 6inch suspension and 2 inch or so BL what size tire would be recommended to run? as far as no rubbing and give me the wider looking stance?
i need to get a steering stabilizer kit me thinks.
is there any difference with the steering that would cause for the need of one?
correct me if im wrong but i've heard that sometimes lifted trucks have a little "play" in the steering would that be a concern as to needing the stabilizer?
If the lift comes with add-a-leafs, it is definitely their intention that you install them. It won't hurt anything if you don't but you may have a bit of Cali lean (front end higher than the rear) if you don't use them. With that combination lift I would personally run 35s on some 20x10 wheels. Would look awesome!
thanks bro i definitely wanna get a lift and make the obs look good! with 35s and 20x10s, would that give me to look of big rims and smaller tires like this
i dont like that look at all with lifted trucks with low pro tires looks ugly imo.
Those you posted look like 22x14 diesels with 35" Iroks. 35s on 20x10s looks more like this:
If that is still too much wheel, step down to an 18" or 17" wheel.
i like that but the only thing i am worried about is the ride being more worse bc with more tire itd absorb more but if i have less then its gonna ride rougher
Exact setup I want for my 88 when its done
still 7.5" of tire, thats about the same as my 04 with 265/70R17s
