2014+ gm1000 drop info
DemoN
Mar 22, 2012
2,662
224
49
I have begun researching drop information for gm1000s and I thought I’d start throwing the info out there. This will include everything from:
kits we’ve seen people use plus comments and reviews of those kits
other components used
pics with drops
stock tires…rub or no
and ect.
I’ll mainly focus on 4/7 drops (because that’s what I want to do)
I know of 3 basic drop kits:
DJM (DJM2507-4/7) 658$ without shocks
http://djmsuspension.com/products/djm2507-46/
McGaughys adjustable kit (34160) 749$ without
Chevrolet Silverado 1500 2014 3/5 - 4/6 Deluxe Drop Kit - McGaughys Part# 34160 - Mcgaughys-Suspension.com
Belltech 4/7 kit (BEL-993SP) 767$ without shocks
Belltech 2014+ Silverado/Sierra 4/7 Lowering Kit
from what I’m hearing, both the DJM and McGaughys flip kits are regurgitated 07-13 flip kits and cause driveline vibration and require a bit of modifying. Belltech uses a new kit.
With McGaughys adjustable kit
With DJM 4/6:
With DJM 4/7:
70205d1400636797-4-7-rubbed-through-my-front-wheel-wells-10294457_10201205471898483_1771925503150383164_n.jpg
I have no belltech pics at all, save the belltech truck.
More suspension info: that silver reg cab has installed coilovers in the front. I do not have a part number for the rear shocks yet.
From Vi-king: c120t shocks
From Vi-king: 12dp600 springs
From Jack-it: 91-3712 coilover mount
going thru all the complains about tire rubbing with stock 20s...i've come to the conclusion that stockers will rub with anything at or above 31" tall.
added: CALTRACS 3404 FLIP KIT APPLICATIONS $369.00
http://www.calvertracing.com/store/caltracs-3404-flip-kit-applications-p-36.html
what is the housing for the k2xxs? gm 10 bolt?
yup. i haven't decided on color...but a reg cab 5.3L :D
:hng: :shake: I looked at them but way cheaper to just make this paid off truck into a project and snag a cheap daily. They do drive nice though, definitely made me want one. Looking forward to progress!
no more kidney bean wheels plz
i'll do what i want. lol but i made this thread so we can have a good spot of all things for street suspensions on the k2xx...not just for my upcoming project :D
I just wrapped up an install on a '14 single cab using McGaughys parts. I used drop kit 34170 and helper bags 34043. I recommend using the 34170 kit over the 34160. The 34170 includes front and rear shocks while the 34160 does not include shocks and utilizes the coil relocators to achieve the front drop over the 2" the spindles provide.
I also recommend NOT using the shock relocators, the ride is pretty stiff with them.
If you have any additional questions let me know.
Fantastic information...thank you
update on this: McGaughys has confirmed there was driveline vibration due to the flip kit pushing the drive shaft into the transmission. the new 2014 kit has corrected this.
2014 Chevy Silverado 1500 All Cabs 3/5,4/6 & 4/7 Adjustable Drop Kit - McGaughys 34170 - McGuaghy's Suspension Online
Nice info you have provided. If anyone has any questions I can help with please let me know.
Do you know if the 34170 Mcgaughys kit requires the drive a haft to be shortened? I've seen a few complaints about vibration. Set at 3/5" do you know if the stock tires (275/55R20) will clear without rubbing?
Ehhh, I am hearing people doing this. You shouldn't have to. The McG's kit is just recycled parts from the 07-13. Belltech corrected the pinon angle and centered the rear wheels by designing a new flip kit.
