24/26 Offset?
billyblanco
Jun 12, 2016
2
I'm new here, so I'm sorry in advance if this subject has been beaten to death. I stumbled upon the forum looking for wheels that would fit my bagged 2011 Chevy Silverado. Been searching with no luck. Seems like I can't find a solid answer, or get mixed responses that contradict each other. What I'm trying to find out and hoping maybe someone here could help me with is; what offset and back spacing will I need to tuck a 24 or 26x10 or 24/26x9.5 inch wheel? No Billets. Don't want to narrow rear. Thanks.
What do billets have to do with narrowing your rear end? Billets are made to order so you can have whatever size and backspacing you want. Plus they look much better IMO
Firstly offset and backspacing tell you the exact same thing, it is just traditionally cast wheels use offset and forged/Billet wheels use backspacing.
If you are not wanting to run billets then you will want to looking for the following for just bagged
26x10 +30mm (6.68" backspacing) or greater
26x9.5 +25mm (6.23" backspacing) or greater
Which ever way the manufacturer classifies the position of the hub face, if you go less than these numbers, you will be in for rubbing issues.
