6Inch Lift TOTAL Lift questions.
kippjr23
May 5, 2012
204
1994 Reg Cab 2wd V6
So Me and my Dad are expanding options and thinking
4inch Susp Lift Rough country
2 inch body lift / or 3inch body lift.
Then run 33x12.5s
Will it rub with the 2inch body lift or 3 inch boyd lfit? Trimming be needed?
Which one would work out better?
Thanks and those who ask about gearing Im going way up in gearing as well.
sorry man, you are correct. Thats gonna be your best routew, 2" body lift should be fine...it def depends on what wheels your gonna run will dictate whether or not it will rub
Well I was thinking just 4inch spindle lift with 31s10.5
Now my dad is talking Bout 4inch with 2inxh Body lift.
Id run 33x10.5
Well i have 15x7 wheels.
Are you going to be running factory offset wheels? Is so you'll be fine!
I fit 305/70 15s on my obs 2wd with just the rough country 3" kit. Rubbed slightly at full lock.
Im thinking about 31x10.5s. Should be a good tire. Lots of options. Ill look into the 305x70 though!
