question on a bracket-rear hanger
i'll try and get pics if i can.
Worse case if u want it, get the whole job done, take it to a locla fab and have a bracket fabbed and welded. Would be cheap and easy....you will not enjoy your 5" with air
You should be good without it. If not then any fab should be able to make something similar. If I remember right it's just a brace for the hanger. There used to be a rivet in it.
yes, I need a notch now with 4", which is why I just said screw it and going lower. If I had smaller tires I would do 3"-4" up front right now too.
:lol:
Silvy is 2wd, pretty sure it doesn't have them. I'll check this afternoon.
