Tailgate not shutting/flying open
Moore
Feb 12, 2012
1,136
227
30
Maryland
So it takes like 10-15 trys of me slamming the fuck out of my tailgate to close it, then if I hit a decent size bump driving down the highway it flys open...any ideas guys?
I've never had to play with the mechanism but have you tried adjusting the latch? Or at least the strikers?
When I bought my ford, it had a camper shell, which took the spot for the gate.
So I had to add the gate, and hardware. When installing, I had to adjust the latches to have it shut properly.
Check the hardware/latches that bolt to the truck next to the tail lights. They should have the ability to adjust
Is it hard to shut? Or just doesn't want to grab/stay latched?
Pretty much what the others have said, check the latches. Also is the handle all the way back in? I could see it sticking part open so it doesn't want to stay latched
normally they get a little rust where the handle mounts and then where they come out of the gate. spray it good with some wd-40 or penitrating oil, then some lubricating oil, that way the latches move freely.
i used to have the same exact problem.
This, my gate did the same. Just sprayed all of the latches and behind the bezel with WD and worked it in. It freed up and works fine
just sprayed like half a can of wd40 everywhere, i guess its working cause it only takes 2 tries instead of like 15. Hopefully it stays closed on the highway
