Wheel bearing or hub?
You might want to double check that the didnt bend the warning tabs and they may be squeeling, i know my brakes were squeeling at the end of their life on and off of the brakes.
but to test the wheel bearing, jack up that wheel, and try to shake it like you would do test ball joints or tie rods, also spin it while in the air to see if you get any bad noises.
From my experience, hubs make more than just a "squealing" noise. It is more of a "hum" or "howl". Try inspecting the pads, and even slapping on lube to the pads. That, or they could just be cheap, noisy pads!
I'll be pissed if it's the pads
