GingerCrews 06 CC build
that digital one should be way darker than my needle gauge. Buy A LOT of 12ga wire, btw. It takes a lot of wiring to get everything setup. I think I went thru 2 spools when I did my horns and gauges (Did them at same time). Might not use as much if u don't twist/braid the wires, but I did...makes it easier to route and looks WAY cleaner.
Got any pics of this "braided wire"
How much was that pod? I was gonna make my own but that looks a lot cleaner
$29.95 you have to call and order
And retains factory mounting clip points so its a breeze to install. Screw making one when there so cheap, it woukd take me hours to make a very shitty version of this
I could make one in a couple min with some abs plastic and a hole saw lol. But that looks so much better I'll probably just go that route. Thanks buddy
Thought you meant like this
I just tied the ends to a drawer handle and put the ends of the wires in the drill chuck....50ft turns into 40ft asap..lol....u just gotta know which ends are which.
guess that works too...I think its minimum 12ga that glowshift recommends when ur wiring it up...check the instructions tho...I doubt it was 10ga minimum
