GingerCrews 06 CC build
:fp:
ur gonna have to make some sort of manifold so u can thread in the sender. Depending if u plumb the bags independently or not, u might not need both senders yet. I have one sender on my tank, the other on the valve manifold that controls my bags.
Found out that my passenger side header is rubbing on the frame, did a little digging and found out that bad motor mounts cause this issue. They have a disclaimer about it as well on their webpage. So looks like its time for new motor mounts
not all the time....My pacesetters and CalSpeeds both rubbed...I replaced mounts...still rubbed...I ended up heating and pushing the primary away from the frame. You can also loosen the mounts and trans mount and shift the motor to the driver side a bit :nerd:
imo...I replaced motor n trans mounts at same time....careful with the heat shields...theyre SHARP as fok....the headers get in the way too
ORDERED!
Glowshit dual air pressue "tinted"
TTS Angled gauge pod
Mcgaughys helper bag kit
[MENTION=126]Ginger[/MENTION]
