Important!: Blower Motor Issue
KoopaTroopaPatrol
Sep 12, 2018
37
So my blower fan will not shut off when the engine is off. Key is out. No power whatsoever. It didn’t start until after a mechanic I took it to recommended that I replace the one that wasn’t working in the first place. Got the new one in the mail and now it never shuts off. So I’ve been living in this Vegas heat without ac. And it’s getting old.
The only way I can get the fan to stop is by unplugging the battery (but then I can’t drive) or disconnecting the blower plug.
What do I do? Replace it again? Or did anyone else have this issue and can give me the step by step to figuring it out?
After I swapped my motor, the second I hooked up the battery my blower would kick on no matter what I did.
Rechecked all my grounds and the problem went away. Was their anything else they replaced that might have involved moving or removing a ground? Other than that check fuses and make sure no exposed wires are touching each other on the blower.
Wonder if a wire was swapped while putting the new connector in.
