Ultimate what hits/what fits, "What size tires can I run with X lift on Y truck?" !!
hey guys recent member here... just a quick question I have a 2013 GMC SIERRA SLE ext cab 4x4 and I am wanting to run Fuel Maverick 20x12 rims...33x12 tires ? just wondering if I can get away with a 3.5' level kit or would these rims need a full 6 inch lift for clearance / no rub issues ??? love the deep dish / lip look and I want to run it for the spring !!! thanks again any help or input would be much appreciated
Hey, would hall mind helping me out!? I'm about to install 3" spindles on top of my 2.5" TGC leveling kit, rear blocks (should I use 4" or 5"?), and also pro comp es3000 shocks in the rear. I just don't know what tires would look best. I was thinking maybe 325 60 18's? Just not sure! I believe the offset of my wheels are +18 or +25. I would like to keep trimming to a minimal. Also, do I need new UCA's to get it aligned?
no way man lol x12's on a 33x12.50 you will need 6" minimum for no rubbing
Hey guys. New here. I just bought a 2014 GMC Sierra 1500 SLT crew cab. I just ordered 295/60/20 nitto Terra grapplers with a 20x9 - 12 offset ballistic jester. I figured I would need a leveling kit so I also ordered a ready lift 2.5" will this fit without a crap ton of trimming?
Alright.. Haven't posted in a while cause I haven't done shit to my truck since the 6.0L. I just bought a leveling kit which is supposed to give me up to 3" of front lift. I would like run 33's on maybe 20's, but also would like a little poke. I like the moto metal 962's because of the deep dish, but haven't set my mind on a wheel yet. Also, what shocks would you guys recommend if I were to go with the full 3"?
no.. you will rub pretty bad..
How much rubbing will be going on on my truck.. I have a 7" TCS lift mine is a 99 2wd. I'm going with 20x12 ion 183s with a -44 offset and a 33x12.50 toyo at 2.
Figured this is where this post belonged...
Noobie here and looking for some help.
I've researched this topic to death and keep finding conflicting results. Right now I've got a BDS 4" lift on my '11 silverado. Fender measurements are approximately 41.5" front, 43.25 rear. 305/55/20 tires (that I plan to keep).
This summer I plan on getting some bilstein adjustables to bring my front end up level with the rear, putting me at roughly 43.25" in the front (duh). I had originally planned to go 20x10 with a -12 offset but cannot decide on a wheel. I fell in love with the fuel octane and unfortunately the only 20" size they come in is 20x12 with -44.
Upon my research I've been able to gather that the popular combo x12s are on a 7" FTS or something similar with front measurements being somewhere around 47-48", which is out of my reach.
I understand the x12 with -44 is significantly wider and absolutely will not fit with only a level on my current set up. However, I have seen two trucks running only a 6" lift and running x12 octanes, one of which is a BDS (the other pro comp, which I think is similar in height), shown here **Wheel Offset 2008 Chevrolet Silverado 1500 Super Aggressive 3 Suspension Lift 6 Custom Rims**
This truck really stumps me because the wheels don't even appear to be too far out of the fender, and I know that the BDS kits have roughly a 1.5" track width increase. I've read on a couple of different places that guys w/ the BDS 6" and 35's have fender measurements of around 44-45, so can I add a 1.25" RCX BL and expect to trim the plastic and call it a day (putting me at approximately 44.5)?
If the x12s won't look stupid I'm not opposed to the nor-cal fender mod to make them fit right. I don't know what it is about that truck that I posted but I love that stance..(I know the rear is a bit higher, but I'm not all that concerned about that).
Thanks for the help and I apologize if this topic has been beat to death.
I see no reason with a 6", x12's won't clear with a fender mod. I was planning on clearing them with a 5" and nor cal mod.
Do you have the 5" RCX kit?
I'm really liking the look of the 6" and x12s…wish I would have done this from the beginning. Hopefully I can get everything to work. Let me know how yours goes -- I'm at the least 3-4 months out until my budget will allow me to get new wheels.
Thanks for the reply.
Hey,
New to the site, trying to pick lift and tires. I have a 2013 Silverado 4x4 1500 extended cab. I am looking at a Superlift 8" lift which Bilstein shocks and Fuel Krank's 20x12 -44 offset with Nitto Trail Grappler M/T's 35x12.50R20. How much trimming will be required low medium or break out the freakin cutting wheel lol!
Thanks for any and all advice.
Does anyone know if 38X15.5X20 Kumho Road Venture MTs with -44offset and a 4.77inch back space will fit on a 1999 GMC Sierra 1500? The truck has a 6" tuff country lift. Currently I have 35X12.5X18 Toyo Open Country tires and have zero problems. Thanks for the help and advice. Also if anyone is interested the tires and rims would be for sell if the above set up works as is.
3" BL, crank up lift, and lots of trimming, metal & plastic. Then they will fit. front end will hate life, and it will be a slug.
Do 36 x 15.50 MTZ, those 20x12's, 3" BL, minor trimming. ball out
