2013 GMC 2500hd DMAX Build
Sounds and looks real good. How long did the down pipe take. I'm doing mine hopefully this coming weekend.
lol, the downpipe was a bitch. i ended up having to yank the heat shield off of it first, then i was finally able to pry it away from the firewall. it took me a good 6+ hours between taking my time and getting pissed off
Sounds good.
Dat landscaping doe.
thanks, ha our landscaping looks like shit, just cant tell :roflpuke: or at least it does to me
needs choo choo horn now
Imo, that's in the plans too. Eventually....
Oh and Marc, here's my catch can after 750 miles.... decent amount of you ask me, and that's not running on a vacuum either.
Sent from a cannoli smuggling warehouse.
Damn that sounds great. There just isn't much out there for sound clips on the LMLs. I've read that these sound quite a bit similar to an LB7 and I'd have to agree.
Yea, it seems like guys are to afraid to delete the emissions crap and void their warranty. I didn't care, guys at dealership will service it anyways as long as its not ridiculous. I just swapped the single band clamps out to all duals and that fixed the leaks and flex in the pipes. Much better now.
Alec, how did you like the fitment of the AFE exhaust? I'm about to pull the trigger on an exhaust and its between the 5" AFE or a Flo Pro kit. I'm gonna take a stab that the AFE kit might fit a bit better from what I notice.
It fit no problem. But buy some double band clamps to use instead of the singles. they leak. also, with the race version of the exhaust like i got, i had to get a longer rear hanger isolator to drop the exhaust down from the rear bumper so the tip wouldnt hit.
here's everything i ordered:
http://www.amazon.com/aFe-49-44026-Cat-Back-Exhaust-System/dp/B004VDQRBI
http://www.amazon.com/MBRP-T5053-Exhaust-Tip/dp/B000OAXP4E
http://www.amazon.com/Walker-33224-Stainless-Hardware-Clamp/dp/B0017LWB8A
http://www.amazon.com/Walker-35296-Exhaust-Insulator/dp/B0019ICENI
Does your 4in. AFE drone/resonate in the cab at any certain speeds? My 5in. does in 6th gear at the mid 60 mph mark and sometimes in 5th gear around 55mph.
my 4" on my LBZ had it bad when torque converter unlocked going up steep grade...being in BC that's like every other road...it was quite loud inside.
